Combining pattern pieces
Thu, 06/26/2014 - 11:14
cherberr
User offline. Last seen 11 years 22 weeks ago. Offline
 Hello Nezat:
The question I have is about combining the bodice and skirt patterns when the skirt has the two darts for the full figure. Do we not change the darts if we are combining the two pieces? I think the darts won't line up if we do.
Thu, 06/26/2014 - 16:50
User offline. Last seen 4 weeks 18 hours ago. Offline
Re: Combining pattern pieces
Dear cherberr,
You can divide the bodice waist darts the same way as the skirt to make sure they are the same and that the darts line up when you join the patterns together.
If you want the dress to be fitted you can sew both darts on either side.
A second option is to sew both darts on either side, but reduce their intake.
A third option is to not sew the smaller darts, this will add some ease to your garment in the waist area. This works especially well for full figures.
I recommend checking on muslin so you can decide which way you prefer most depending on your body shape. Check the fit in the mirror from different angles to help you decide.
