Copying the back skirt shell for lining
Fri, 10/18/2019 - 01:58
montine
User offline. Last seen 4 years 25 weeks ago. Offline
Hello Nehzat,
Please I need clarification. I am currently watching the Skirt Sewing from a Pattern Online Video i am on video 7. about 6  minutes into the video, you started to copy the back skir pattern to create the pattern for the lining.
I want to know if you copied the center back dart also, it was not shown in the video. Also about 15 minutes into the video you said "also to prevent a lining from getting caught in the zipper we need to push it back by 5 millimetre measure 5 mm from here" From where? Is it from the center back dart leg or from the center back line on the waist.
I am confused because I am not seeing the center back dart on the back lining pattern.
Austin
Wed, 01/26/2022 - 19:47
Re: Copying the back skirt shell for lining
Greetings
We need to copy the center back dart as well.
The 5mm you mentioned is from the leg of the dart, which is shown in the video later as well.
Best wishes.
