How to fix sway back problem
Fri, 06/12/2020 - 16:20
relmountassir12
User offline. Last seen 5 years 14 weeks ago. Offline
Hello ,
when I tested my dress. I had the sway back issue when . I tried many alteration and methods using books , videos,  you tube, and google search, but I still have the same issue.
enclosed is the photo of the dress when I tried it.
Thank  you any help to fix this common issue
Wed, 01/26/2022 - 20:09
Re: How to fix sway back problem
Greetings
Usually when the intake of the side bust dart in the front bodice block pattern is not enough, the sway back problem happens. Incase you have used video lessons from our website to make the bodice block pattern, you need to add to the intake of side bust dart.
If you have used a ready made pattern, and there is no side bust dart on the garment, you can create them, if the style of the garment allows it.
You could have the back bodice length be longer than it has to be.
Best wishes.
