automatic needle threader
Wed, 02/23/2011 - 10:20
carollnhn
User offline. Last seen 15 years 18 weeks ago. Offline
i just bought a new machine with auto matic needle threader  but it is not working   at all   what do i do  to fix this
Fri, 02/25/2011 - 18:36
Re: Automatic needle threader
Dear Carollnhn,
On my Singer, I need to pass the thread through the guide right above the needle then raise the needle to its highest position.
Next pass the thread through the hook on the needle threader.
Bring the threader down by pulling on its lever, as far down as possible using your left hand.
Now another very small hook of the needle threader will position itself in front of the needle eye.
The hook is facing downwards. You need to pass the thread in front of the needle and catch it on the hook. keep the thread taut in your right hand.
By rotating back and pulling the needle threader lever gently upwards to its previous position, while moving your thread towards the needle, you will make it possible to pass a small loop of thread through the needle eye.
Open the loop and the needle is threaded.
Please let me know if this helps.
Happy sewing
