Back Bodice Block
Mon, 03/11/2013 - 10:39
phusch
User offline. Last seen 4 years 11 weeks ago. Offline
Hello,
I made my bodice block pattern, front and back, but decided I was 1 cm long in the back.  Is there a way to alter my block pattern in the back without affecting the side seam length or the front pattern.
Thanks for your help, Pat.
Wed, 03/13/2013 - 10:50
User offline. Last seen 2 weeks 8 hours ago. Offline
Re: Shortening the Back of Bodice Pattern
Dear Pat,
You just need to deduct 1 cm form the back bodice length, that you used to draft your pattern. Then draft the back bodice block pattern again. The back and the front patterns will match with no problems.
