checking measurement.
Mon, 11/19/2012 - 01:46
rrunnerss1
After adding up the length for back and front pattern across the darts my different was 0.1. Do i still need to ajust it ?
Sun, 11/25/2012 - 11:27
Re: Checking measurements
Dear rrunnerss1,
I am not sure exactly where this 1 mm difference is, however a 1 mm difference can be ignored in most locations on a pattern.
Mon, 11/19/2012 - 01:48
rrunnerss1
pattern ajustment
Can i sew my pant without making all those ajustment on the pattern. like the side seam crotch etc?
Sun, 11/25/2012 - 11:33
Re: Pattern adjustments
Dear rrunnerss1,
It is easier to make any adjustments if needed to the pattern, instead of making changes to the pants once you have started sewing it. For example you may need to increase the length of the crutch on the front and back, but you may not have enough fabric to do so. That is why I recommend making any adjustments to the pattern before cutting your fabric.
Mon, 11/26/2012 - 04:47
rrunnerss1
Thank you.
Thank you.
