Correct stitches
Thu, 12/13/2012 - 08:22
pepsi1
User offline. Last seen 12 years 41 weeks ago. Offline
Hallo everyone my name is Perpetualand  l have a Janome Deluxe machine am failing to get the correct straight stiching on my machine may you please help me
Thu, 12/13/2012 - 18:13
Re: Straight Stitch
Dear Perpetualand,
There are many reasons why a particular machine might not sew properly. I suggest that you watch the sewing machine essentials video lesson, especially the Janome section. Since there are a lot of similarities between different machines you will be able to thread and set up your machine correctly, by watching this lesson.
If your machine has a different set up, for example the bobbin case is built in, on top of the machine table by the needle plate. Then you can watch the Singer sewing machine in the same sewing machine essentials video lesson. By watching the whole lesson you will be more familiarized with sewing machines.
Happy Sewing,
Fri, 12/14/2012 - 03:31
pepsi1
Thank you let me watch the
Thank you let me watch the videos and hopefully l will be helped
