front and back crotch line extension (pant block pattern)
Thu, 02/23/2012 - 23:42
vbaouy
when i  do the pant crotch line extension on the back or front piece, is it ok if i measure a little bit less so the pant can be fitted to my thigh. If it's ok to do so, what is the limited measurement do we allow to take off from the crotch extesion?
Wed, 02/29/2012 - 20:19
Re: Reducing the Crotch Extension
 Dear vbaouy,
Yes you can reduce the crotch extension. You need to reduce it a bit as I show Here. Do a test fitting using muslin, then make further reductions if you want.
