how to use gather attachment
Wed, 10/10/2012 - 23:58
sudi
User offline. Last seen 12 years 49 weeks ago. Offline
hi ,i am trying to make a bed skirt with gathers but im not getting thrugh useing parrell stiches so i plan on buying the attachment can u show me how to use one please,
Thu, 10/11/2012 - 12:26
Re: Sewing Parallel Stitch Lines for Gathering
 Dear Sudi,
For standard sewing machine you can follow the below instructions.
If you align the raw edge of your fabric with the guide lines of the needle plate you can sew a straight line parallel to the raw edge of your fabric. To sew the second row of stitches parallel to the first line, it is enough to align the edge of your fabric with another guide line on the needle plate.
If the needle plate does not have clear lines, you can apply a piece of masking tape and use it as your guide. Make sure the edge of the masking tape is parallel to the needle plate guide lines. To sew the second line of stitches, move your masking tape closer to the needle. Again make sure the masking tape is parallel to the guides on your needle plate.
The gathering attachments usually come with instructions and diagrams to help you. There are also video on YouTube for different sewing machine brands and their gathering attachments.
Happy sewing
