Kurta without zip and center darts
Wed, 05/16/2012 - 03:06
rosie_vora
I am making a pattern for Kurta which has no zip in the centre.  How do I draft this pattern as the block pattern shown has centre darts with zipper in place.  Can you please explain as this kurta has no side darts and no center darts in front and back and is loose fitting.  If this is loose fitting without darts will this kurta fall without wrinkles.  Please explain.
Also many thanks for the sleeve drafting.  It is very well demonstrated.
Rozmina
Wed, 05/16/2012 - 14:57
Re: Kurta without Zipper and Center Dart
Dear Rozmina,
Thanks so much. To make the kurta without a zipper or any waist darts, you need to align the straight center back line of the pattern with the fold line of your fabric. This means that you ignore the center back dart of the pattern.
You also ignore the front and back pattern waist darts when you sew the garment. If you are sewing a women's kurta I suggest that you sew the side bust dart to make it fall nicely without any ripples.
Since you are not sewing in a zipper on the center back or the sides, you need to add some ease on the front and back pattern side seams so that the garment can be worn easily. On the front pattern make sure to close the side bust dart and tape it in place. Then add a few cm to the top of the side seam and also extend the hemline out by the amount you like at the side seam and connect the marks for both the front and back patterns.
To give you a better idea, I will give you an example of the changes that are required to the pattern in order to style it as a loose fitting A line dress or (kurta).
  • After closing the side bust dart on the front pattern. Extend the armhole out at the top of the side seam by 1 cm on the front pattern.
  • On the front pattern extend the hemline of the skirt out by 5 cm. (here we are using the straight skirt block pattern) Connect the marks. This will be the new side seam for the front pattern.
  • On the back pattern extend the armhole line out at the top of the side seam by 1 cm like the front pattern.
  • The hemline should be extended by 5 cm plus the distance between the straight center back line and the center back dart line, level with the bottom of the back pattern armhole. This could be a small amount of just a few mm. Measure this distance. Lets say it is 4 mm. So for the back pattern you need to extend the hemline out by (5 cm + 4 mm = 5.4 cm) Doing this will ensure that the front and back pattern side seams will have the same angle and length.
  • Since the side seams are at an angle they will hang lower and will not give you an even hemline. To fix this, first extend the lower hipline and cross the new side seams on both patterns.
  • Then, measure the distance from the center back or center front lower hipline down to the hemline. What ever this distance is, you need to measure and mark it from the lower hiplines on the new side seams for both patterns.
  • You will see that the mark falls a bit higher than the hemline. This is what we want. Draw a curved line from the new mark merging it gradually with the previous hemline, at the previous side seam. Do this for both patterns.
  • Then you add the seam allowances. Make sure that the front side bust dart is closed when you do this. When you want to place the patterns on the fabric, open the side bust dart on the front pattern so the pattern lays flat on the fabric.
Make sure to test the pattern on muslin before cutting your main fabric.
I hope this explains it.
Thu, 05/17/2012 - 04:08
rosie_vora
Kurta
Many thanks for the prompt response.
Regards
Rozmina
Mon, 05/21/2012 - 06:23
rosie_vora
KURTA
I tried making kurta on muslin fabric and observed that by not taking the waist dart it is very loose.  If I take the waist dart it looks perfect fit.  Now in order to take the waist dart how should I calculate the waist dart - my hips are 43 and waist is 36 left with 7 inches, does this mean that each dart is 1 and 3/4 inches.  Doing this does not appear to be very neat.  What am I doing wrong.  Please explain and thanks.
Wed, 05/30/2012 - 16:35
Re: Calculating the Waist Dart Intakes
Dear Rozmina,
You need to divide the difference between the lower hip circumference and the waist circumference by 9. So in your case 7 inches divided by 9.
7 inches is 17.78 cm, 17.78 cm divided by 9 is 1.97 cm we round it up to 2 cm. Therefore each waist dart should be 2 cm wide. That`s about 0.8 inches. This is a perfectly acceptable amount for waist darts. A waist dart can also be much less than this. The narrower the waist compared to the lower hip, the wider the waist dart intakes. The opposite is also true.
