Pannel dress question: Understitching around neckline
Fri, 09/28/2012 - 11:38
ros_b
User offline. Last seen 11 years 39 weeks ago. Offline
Hi there!  Awesome, awesome videos!  I have one quick question, think that it is chapter 62 in the panel dress tutorial.  After I have sewn, by machine, the neckline, I am a little bit lost on the understitching, next step.  Am I correct in thinking that I sew, by machine, 1 cm down from the seam, on the facing side, in order to tack down the seam allowances and stop the facing from riding up?
many thanks!
Wed, 10/03/2012 - 14:37
Re: Panel dress question: Understitching around neckline
Dear ros_b,
Thanks so much for the kind words. Yes you are correct, the only thing is that you need to sew 1 mm down from the seam not 1 cm as you stated.
Sat, 10/06/2012 - 21:43
ros_b
Perfect! Thanks!
What a nice difference that added touch made - glad that you caught me before I made a big old line of stiches 1 cm instead of 1 mm!
Tue, 10/09/2012 - 13:17
 Dear ros_b You are very
 Dear ros_b
You are very welcome.
