Inconsistent stitches - Janome MyLock 504D Serger
Sun, 03/27/2011 - 22:45
JB2009
User offline. Last seen 15 years 14 weeks ago. Offline
Hi There
I just received a 10 year old Janome MyLock 504D.  It works fine, on the most part, but sometimes it has inconsistent stitches.  I took a piece of cotton and flossed it between the tension disks to remove any lint, as well as cleaned and oiled the rest of the machine according to the manual.    I checked the treading and ensured that the thread is placed correctly between the tension disks.  Any idea on how to fix this?
Thanks so much!
JB
Wed, 03/30/2011 - 16:22
Re: Serger (Over Lock) Inconsistent Stitches
Dear JB,
Some ideas I have that you can try to see if there are any improvements in the consistency of your machine stitches are:
  • Opening the looper covers in the front and the side and vacuuming these areas using the hose of the vacuum, you can also vacuum the thread tension discs.
  • Making sure that the machine is threaded according to the manual.
  • It is also best to use smooth threads.
  • When sewing try to keep a steady speed. Fluctuating between high and low speeds may cause inconsistencies in the stitching.
  • If the blade that cuts the fabric as you sew, is worn out and blunt, it may also cause problems with the stitching.
  • Make sure you have new needles in the machine.
Try to make these changes, if you still have issue with the stitching you need take it in for repair.
