Lining fabric
Tue, 06/24/2014 - 17:21
phusch
User offline. Last seen 4 years 13 weeks ago. Offline
 Hi Nehzat,  I have some satin fabric and I need to ask you if it could be used to line a skirt.  Would satin be to heavy or bulky?  Also would I need to add some ease to the block pattern?  Thank you once again.  Pat
Wed, 06/25/2014 - 11:17
Re: Lining Using Satin
Dear Pat,
There are different weights for satin. If your satin is heavy you need to use a heavy fabric for the skirt.
I suggest you do a test fitting using muslin. You may like the way it fits, otherwise you can add some ease to your pattern.
