shorten sleeves
Mon, 09/13/2010 - 13:47
carol_
User offline. Last seen 11 years 3 weeks ago. Offline
I need to shorten the sleeves on a jacket. The jacket has a cuff with a button hole. I thought I could remove the cuff but the button hole is the problem. What is the best way to shorten the sleeves?
Thank you
carol
Sun, 09/19/2010 - 12:36
Re: Shortening the sleeves with cuffs on a jacket
 Hi Carol_,
You may be able to shorten the sleeves above cuffs. So remove the cuffs, mark the excess fabric along the edge and baste the cuffs back on for a fitting, before cutting away the excess fabric. Make sure to bend the arms by 90 degrees at the elbows to test the fit.
Since I can't see the jacket I am not sure if this technique applies to your sleeve style. But it is the best solution from what you have written here.
Hope this helps, Happy sewing.
