wide pants adjustment
Tue, 02/19/2019 - 16:06
missrefano
User offline. Last seen 43 weeks 4 days ago. Offline
Thank you for your previous help with princess seams.
I have drafted the basic block for trousers and wanted to create a wide leg pant, while keeping the waist, darts etc. I have learned from other sources that I can widen at the UPPER THIGH but that measurement isnt in the video. I took that measurement and added it to the block, and began to widen from the lower hip (outer seam ine) and the upper thigh (inner seam line)Two questions: Is this a correct assumption and is there a video on widening pants?
I appreciatae the video tutorials very much and I could use help before I begin cutting fabric.
Fri, 02/22/2019 - 12:41
Re: wide pants adjustment
Dear Missrefano,
From the explanation you gave, it looks like you have done the adjustments successfully, to widen the upper thigh.
You can also watch Chapert 5 of our Pants Pattern Styling Video lesson entitled Styling the Pants Block Pattern: Straight Style. Here you will find an explanation on how I widen the legs of the pants block pattern.
Happy Sewing,
